Like this request (https://getmusicbee.com/forum/index.php?topic=24547.0) it would be great if search & replace can convert multiple values at once for a given tag. How about adding a new "Multiple Search & Replace" command to the plugin that allows people to list a great number of paired search and replace values and converts them one shot? Also allow to list multiple values for search for a single replace value, when entering paired values.
Is there a way to run multiple presets at once?I can select multiple presets but have to run each one individually.
Can someone also tell me what the 2 buttons to the right of the long text field are for?
Quote from: redwing on February 27, 2018, 09:47:34 AMLike this request (https://getmusicbee.com/forum/index.php?topic=24547.0) it would be great if search & replace can convert multiple values at once for a given tag. How about adding a new "Multiple Search & Replace" command to the plugin that allows people to list a great number of paired search and replace values and converts them one shot? Also allow to list multiple values for search for a single replace value, when entering paired values.its done as new asr preset:http://www.mediafire.com/file/1wwufnm9dj27wc0/mb_TagTools_2018-03-01.zip
It just crashes MB if there's any syntax error (for instance if a slash is used instead of a backslash). I also noticed this when entering a wrong regex pattern in other presets. Can you make it not to crash in such a case?
Quote from: boroda74 on March 01, 2018, 06:02:44 PMQuote from: redwing on February 27, 2018, 09:47:34 AMLike this request (https://getmusicbee.com/forum/index.php?topic=24547.0) it would be great if search & replace can convert multiple values at once for a given tag. How about adding a new "Multiple Search & Replace" command to the plugin that allows people to list a great number of paired search and replace values and converts them one shot? Also allow to list multiple values for search for a single replace value, when entering paired values.its done as new asr preset:http://www.mediafire.com/file/1wwufnm9dj27wc0/mb_TagTools_2018-03-01.zipThanks a lot! I just tested it and it's working great. How many pairs do you think it can handle entered in the custom text box?
If you don't mind me asking, what were the parameters of your test?
Quote from: redwing on March 01, 2018, 07:03:26 PMIt just crashes MB if there's any syntax error (for instance if a slash is used instead of a backslash). I also noticed this when entering a wrong regex pattern in other presets. Can you make it not to crash in such a case?
