Author Topic: How to move spectrum visualizer????  (Read 454 times)
fishy33
How do you set the spectrum visualizer to the top of the bottom panel instead of being stuck in the right-hand corner? Like how do I move what's in the red circle to look like the spectrum visualizer in the image with the blue circle?!?!?!?! This is driving me up a wall. I can't find the setting. PLEASE AND THANKYOU!!!!
Last Edit: December 15, 2022, 07:58:29 PM by fishy33
suggest that you want to right-click player controls at bottom, select "panel layout", and untick "untick spectrum visualizations". then click mb menu> view> arrange panels. drag "visualizer: spectrum" from right part of window to left part into appropriate section.
but i'd recommend to try this plugin instead. and the latest forum posts about it (some fixes are described there).
do you agree that this much better looks?
than this:
