Author Topic: 3rd prty skins (HI DPI) looks pixelated on newer versions  (Read 693 times)
marciozomb13
After updating to latest version 3.5 8367, my skins with support to hi dpi are looking pixelated, to troubleshoot i rolled back some versions and i can confirm the last version working flawlessly is 3_5_8249, so the problem on version after 8249. Could you please check this out?
https://imgbox.com/nExBUslz 8249
https://imgbox.com/iAKHaGsN 8367
Look to the play/pause buttons and other...
does this make any difference?
if it doesnt make any difference, which skin are you using and what is your windows DPI setting for the screen
Last Edit: December 09, 2022, 09:44:04 PM by Steven
marciozomb13
Thank you for your reply, unfortunately 8379 p didn't solve it.
I'm using a 4k monitor:
Skin is Fluenx Dark - Segoe Variation (but happens with other skins)
Settings:
https://imgbox.com/NhqusHAk
Last Edit: December 09, 2022, 10:10:07 PM by marciozomb13
