Author Topic: Help fixing playists imported from phone  (Read 454 times)
mstrhck
Hi! I recently wiped my hard drives for a new OS and forgot to save my playlists. I managed to import the playlists from my phone, but all of the links/names are wrong....my phone player is Rocket Player. I've completed the remap function, but this only partially solves the links. For instance, song artist is a pound sign or a track number. If anyone could help me so I don't have to redo all of them, I would really appreciate it.
Welcome to the forum mstrhck
That sounds like it should be easily solved by using a text editor such as Notepad++ and use its search and replace function.
mstrhck
Hi! Thank you for the tip. For some reason I thought the playlists were saved in a non-plaintext format so I ended up just powering through re-locating the files.  ;D
At least I learned to store my playlists folder in a directory I always back up. Have a great day.
