Author Topic: Something causing volume leveling?  (Read 557 times)
cartman005
This is hard to describe, but recently something seems to be limiting the volume of my tracks in MusicBee. It is most noticeable if I start playing a song loudly and then seek to the middle of the track. The volume will suddenly drop to a lower level. If I restart the application, the problem usually goes away but then comes back after a few tracks.
I have my output set to DirectSound but I have also tried WASAPI and I get the same result. I have no replay gain tags on any of my tracks and this issue does not seem to occur if I play the files in VLC. I am running Windows 11 so it is possible that this is something being caused by Windows but I cannot figure out what.
Can anyone give me any ideas of what could be causing this? Thank you!
Sounds an awful lot like this thread here: https://getmusicbee.com/forum/index.php?topic=37652.0;  try the solution that worked there, i.e. replacing bass_aac.dll with the latest version (https://getmusicbee.com/forum/index.php?topic=23454.0).
