Author Topic: Can't delete(update) lylics  (Read 414 times)
lamrongol
I've installed mb_KGetLyricsPlugin but it got error and saved error message as "Lyrics".
I uninstalled the plugin and delete the lyrics manually.
However, the error lyrics remains in lyrics panel.
Try deleting the contents of the lyrics cache folder as decribed here:
https://getmusicbee.com/forum/index.php?topic=37509.msg206008#msg206008
Also be sure the plugin has actually been removed from the MB "Plugins" folder, if not, delete it manually.
lamrongol
Thank you, I solved at this time.
However, I want to update cache when lyrics are changed.
