Author Topic: Album art being cropped when clicking main panel.  (Read 804 times)
Fsac
Howdy folks,
This is a bug(?) I've been wrestling with for over two years.  Never quite found a fix...
For some reason, after selecting an artist/album with 9 or fewer songs, and then click the main panel, approximately 10% of the bottom of the album art gets cropped out.  I can "fix" the art by either clicking another artist/album and then clicking back, or by refreshing with F5... but clicking the main panel again causes the clipping to occur.
Obviously, in the grand scheme of things, this is about the most minor of annoyances, but an annoyance all the same.  Any ideas?
Shown: before and after the click...
Firstly make sure you are using the latest MB version from the downloads page, or the v3.5 beta
If it still happens, can you send a link to your settings file (help/ support/ view settings)
Fsac
Thanks for the reply,
Fresh install of 3.48033 this morning (reformat, imported old settings.)
Settings available at: https://pastebin.com/d5GwXyxg
Assuming you're not using the Store version, try again with the latest version (3.5.x) available from the first forum topic. Once installed, come back here and apply the latest patch from my signature below.
Fsac
Confirmed as still happening on 3.5.8358
Thanks. Steven will take a look at the settings file you provided.
Last Edit: November 20, 2022, 12:27:29 PM by phred
i also need:
\AppData\Saved Settings\Layouts\Standard.tab-layout
if you dont know where the AppData folder is, use Help/ Support/ Open AppData Folder
Fsac
i also need:
Sure thing,
https://pastebin.com/VYss7FR5
thanks - i am now able to reproduce the issue so should be able to fix it
