Author Topic: last.fm: Could not create SSL/TLS secure channel  (Read 415 times)
Selevra
It's me again and I still have trouble connecting from my PC to last.fm via MusicBee (see https://getmusicbee.com/forum/index.php?topic=37284.0). I also tried to get help directly in the last.fm forums because using the last.fm desktop scrobbler does also not work, but without any success (see https://support.last.fm/t/login-to-last-fm-from-any-desktop-scrobbler-app-not-working/66215/16).
Today I got a new error message from inside MusicBee, which I was hoping could help identifying the problem on my PC:
"Update on last.fm failed: The request was aborted: Could not create SSL/TLS secure channel"
Any ideas what I can do to fix it? I use Windows 10 and have the newest updates installed!
Thank you very much in advance!
Last Edit: November 16, 2022, 08:28:10 PM by Selevra
Selevra
Since nothing seems to work I reset Windows and now it is finally working again! Yiha!
Would have loved to know what the actual problem was, but ok, it's working again and so I'm happy.
=> Problem solved!
Last Edit: November 16, 2022, 08:29:10 PM by Selevra
