Author Topic: wrong playlist numbering (while using grouping it count group title)  (Read 315 times)
kavnda
I am using version 3.5.8296 on windows 10 machine
I found out that if I group items of a playlist musicbee will count the group header as a song which will miss up the playlist items count.
as you can see the item count start with 2 instead of 1 as musicbee count "circle the drain" as a song. and the same thing for item 5 that should be 3 instead. :)
as the playlist item count increase and the number of groups increase, the discrepancy of the playlist items count will also increase.
I cant reproduce this. There must be something else going on, so can you send me a link to your settings file (help/ support/ view settings)
kavnda
sorry for the late reply. I added the settings file in the following link.
 setting file link
I also tried to experiment a little and found that this bug only appears in dynamic playlists such as (recently added, recently played ...etc.) but for static playlists the counting work fine.
dynamic playlist:
as you can see the bug appears
static playlist:
the bug does not apear
Steps to reproduce the bug:
1.select dynamic paylist (recently added)
2. click header menu
3. select group by
4. click set group by field
5. click on any field
I can reproduce the issue using auto-playlists. The # field doesnt really make much sense for an auto-playlist as there is no set position in the playlist like there is with a static playlist - MB just uses the row number for auto-playlists. I wont make any changes as a solution would be more complicated than warrants for the issue
