Author Topic: Tag Editor  (Read 828 times)
rpsibew110
First off, thank you for writing such a useful and easy-to-use program.
In the music tab in the main panel, when pressing shift+enter, the tag editor shows up at the bottom of the main panel.
If I change the tab from Music to Music Explorer, the tag editor pops out in a separate window.
Is it possible to have the tag editor at the bottom of the main panel all the time?
Thank  you.
EDIT: I took a couple of screen shots. To help explain. Shot one is how I like to have it all the time. Shot Two is what happens when switching the tab from Music to Music Explorer. Notice the red highlights at the top and bottom of the shots.
Last Edit: November 10, 2022, 10:51:03 PM by rpsibew110
The Incredible Boom Boom
I think the downwards arrow icon next to the close icon will pop it out.
rpsibew110
The way I read the OP, they want the Tag Editor in the main panel all the time. Including when using the Music Explorer. There is a "show in main panel" in the top right corner of the Tag Editor when in the music explorer. But it does not do what it says. This might be intentional, or might be something Steven overlooked.
What say you, Steven?
Last Edit: November 11, 2022, 02:29:38 AM by phred
The behavior was intentional but i guess there is enough room for it, so its supported now
rpsibew110
Thank you very much.
Here is $50
Thanks for donating $50.00 USD to
