Author Topic: Library Quiz  (Read 3983 times)
  • Heal The World
Download the plugin from the add-on link here.
NB: Only works with MusicBee 3.5.8338 and later versions.
I came across this thread some time ago and also thought this would be an interesting and fun thing to have in MusicBee.
Probably not exactly what is described there, but it's close.
All comments are welcome. Let the games begin!
Installation
- Download the mb_LibraryQuiz zip file.
- Then locate and select it from MusicBee > Edit > Preferences > Plugins > Add Plugin
- Lastly, dock the "Library Quiz" element to any panel of your choosing in View -> Arrange Panels...
How It Works
- The plugin will pick a random track from your library.
- Then you'll have to type in whatever values you think correspond with the track tags.
- Your answer will only be evaluated once the field is out of focus i.e when you move on to the next field or click anywhere outside the current field.
- After evaluation, the correct answer will get displayed on that specific field and the scores will get incremented accordingly (1 point for each correct answer).
- Clicking on the track's correct album cover will also earn you a point.
- The round artist picture does not do anything; it's only there to jog your memory.
- You are free to make an attempt on any or all of the 6 fields - you won't get penalized for leaving a field unanswered.
- Click on the track title when you're ready to move on to the next round.
Customization
- The colours used by the plugin are that of the current skin.
- If you're not entirely happy with some of them, you can override them from this folder ...MusicBee\AppData\mb_LibraryQuiz\Skins
Last Edit: November 05, 2022, 03:31:42 PM by Mayibongwe
Strength and Honour (2025)
Gauld
Hello,
I have an error when activating the plugin :
I have the latest version though :
  • Heal The World
Oh man, I'm beginning to build a reputation for getting off the wrong start when it comes to plugins.
In English, I imagine the error message says something along the lines of "unable to initialise plugin"?
Has anything been written to the Activity.Log file in ...MusicBee\AppData\Library Quiz?
Are other users also getting the initialisation error?
That's not the latest (patch) version.
You can find 3.5.8338 here:
https://getmusicbee.com/patches/
@Mayibongwe
It might be good to specify that minimum required patch version in the start post?
  • Heal The World
@Mayibongwe
Will do that right away. I never thought it would require a minimum patch version.
Trying it now on 3.4.8033 P , I can see that it's failing.
Gauld
Yep, it was an intialisation problem :-)
My bad, with the last patch it works !
I'll test it asap.
Last Edit: November 05, 2022, 03:36:22 PM by Gauld
  • Heal The World
Nice. Glad to know that's all it was.
Thank you both for reporting that important bit.
