Author Topic: Moving from Inbox  (Read 280 times)
Gren
So I have dragged a folder to the inbox, made changes to tags etc and I'm now ready to move the album to a library.  I have multiple libraries.  If I just send to Music Library, it works as long as I have the correct library open before I start.  I would like to select which library to send the album to.  If it ends up in the wrong library I would like to be able to move the album to the correct library, but I cannot find a way to do that.  Help would be appreciated. Thanks.
There's no need for multiple libraries.
Instead of multiple libraries, where you have to choose which one to use each time you open MB, try using filters. They're much more convenient as you can move/copy tracks between filters with no need to restart MB. Check the Wiki and then search the forum for further information.
