Author Topic: Is it possible to put a "Play"-Button before each song (like in Spotify)?  (Read 482 times)
Adson
I wonder if it is somehow possible to display such a button before each song.
Right now it's a bit annoying to either use a double click or select the song and then click the play button at the bottom to start a song.
Maybe it can be done already, but unfortunately I don't know how.
Thanks for your help  :)
Have you tried using a hotkey? By default that's Ctrl+P but you can change it in settings.
Coogan
Is a double click really that much of an inconvenience?
My MusicBee Version:
3.5.8878
