Author Topic: Lyrics - sub menu to select provider  (Read 676 times)
Tybot
This just crossed my mind and I wanted to see if anyone else would find it useful.
When right clicking the lyrics panel, in the menu where you can choose to redo the search, search using Google and so on; I propose to add a sub menu where you can choose a specific provider directly without having to go through them in the order you've chosen in preferences.
I thought it would be useful if you're tagging a metal album for example and your usual providers hit or miss but your confident that metalkingdom have them all (and properly formatted). Instead of changing the priority order in preferences, you could just right click and select the appropriate provider directly.
