Author Topic: Library Report Plug in  (Read 504 times)
manishboyradio
So i have installed the custom library report generator, however i am having issues generating one the way i would like to have it, i would like to generate a track count of the all the Genre's and The track count of all the the artists i have, any ideas?, i would appreciate any help. Thanks in advance
Andrew
Please post your issue/question on the thread for the plugin you're referring to.
I'm locking this thread.
i have temporarily unlocked this thread as i suspect there is no plugin topic in this case
... i suspect there is no plugin topic in this case
Isn't the AR&RT plugin the only way to get custom reports?
manishboyradio
Yes , that is what i was referring to,  i can't seem to get the results i am looking for. Per my post, what is the correct way to get those results?
Thanks
Andrew
