Author Topic: Search dupe same title - artist in same folder  (Read 271 times)
cordobaweb
Hi everybody:
I need to search for duplicates that have the same title and artist but are in the same folder. Can it be done on musicbee?
Yes it can be done.
Create a virtual tag like this:
Then let the Duplicates Manager use that tag as criterion.
(you need a recent version of MusicBee for this to work)
What hiccup says will work. You can also filter by the folder name "tag" in the column browser, or go to that folder in the computer node and run the duplicate manager on artist and title from there.
