Author Topic: Expandable Disks for multi-disk albums  (Read 2303 times)
J.S.B.
It would be nice, for multiple-disk albums to expand or minimize certain Disks (see picture)
https://www.mediafire.com/view/65kezkp3sdr048b/Unbenannt.png/file
The album in my case for example has 38 CDs. It would be much easier for me to navigate to the CD I want to listen to by "closing" certain CDs.
Sorry for my bad english :)
Last Edit: September 25, 2022, 03:36:55 PM by Acromar
+1.
ctrl-clicking on "down" arrow might expand/collapse all disks.
AMoonRabbit
Isn't this functionality already in MB? If you click the far right of each CD heading, it will collapse that entry.
J.S.B.
Is it? Do you mind posting a screenshot? I cannot find it :-X
AMoonRabbit
If you look at your screen shot, where it says CD 1, to the far right, there's a triangle pointing downwards. Pretty sure if you click on that it should collapse that disk.
Last Edit: October 16, 2022, 11:20:33 AM by AMoonRabbit
J.S.B.
Ah  ;D That was created by me with paint as an example of how I would imagine it to look. But I take it as a compliment that it looks legit to you  ;)
AMoonRabbit
Hmm, you fooled me, but I am sure that I did do this. You'll have to wait until I get home as my current device is linux based. I'll update then.
AMoonRabbit
Managed to nab a work machine to test with but clean install doesn't offer it....So I must have been dreaming  :-[
+1 from me
