Prior to the last update, the number of columns as well as their width were consistently spaced:
However, 3.5.8296 has changed things a bit. With the same settings as the preceding update, if no column restrictions are in place, albums will display as a single column if any track's title is too long, and the rest will be inconsistently spaced:
If columns are restricted to their pre-update numbers (2 for me in this view), the column spacing will be inconsistent between albums (in the same view):
I'd chuck this in bug reports as I don't feel this is intentional, but I figured I'd ask if I'm just missing a setting. I've had a fairly close look through all relevant settings and nothing is standing out to me.
Thanks guys!
