Author Topic: Centrol Dark + Centrol Light — High DPI bitmap skin with centered media controls  (Read 30890 times)
NikoMuniz
Proudly presenting Centrol Dark + Light, a bitmap skin in two color tones, with centered media controls. An accompanying toolbar icon set is in development.
Please consider this a Beta release, if you find any visual bugs please post your findings, preferably with a screenshot of your MusicBee layout.
Tip: Use MusicBee's built-in automatic Time Of Day skin switcher setting to alternate between dark and light versions throughout your day.
Download:
Centrol Light / Centrol Dark
Download layout file:
Layout
Credits to diego and mvana for providing their skin source files; credits to phosphoricons.com for their icon set.
Download:
Can you inform what font you used in the image preview?
Haste
KevinarCZ
Can you share the source files, please. Thank you
Intel Core i5-4690K ■ Asus Z97-Pro Gamer ■ Kingston KVR13N9S8/4 DDR3-1333/CL9/16 GB  ■ MSI GeForce GTX 1080 Ti GAMING X 11G ■ Corsair RM650x ■  Dell S2240L
► Creative X-Fi Platinum Fatal1ty Champion Series ■ NAD 705 ■ B&W DM302
Johan_A_M
This is a great skin, thank you very much! Would it be possible to raise the contrast of the text in the status bar just a bit higher? I find the text in Dark just a tiny bit too dark, and the opposite in Light.
Thanks again for such a well-composed skin!
How to change the colours of a skin that you like.
Johan_A_M
Thank you! With a bit of color picking, it all went perfectly well!
A tiny bit strange for me was that while the status bar text was found in
 element id="Panel.StatusBar.Default"
I could not only change the fg for the text, because then the bg went all black, so I needed to at least include bg:
 <element id="Panel.StatusBar.Default" bg="47,53,61" fg="240,240,240" />
I seem to recall that the position of the status bar and the player controls also play a role here.
E.g. status bar below or above the player controls, and/or player controls positioned in the bottom panel or the top panel.
KevinarCZ
Dark theme is a beautiful. Thank you very much.
purpleplum
Thank you for beautiful, clean, stylish modern skin!
Your skin truly compliments Musicbee well!
Is there a way to make the bottom right "selected file / queued" info fonts brighter?
T010
Thank you :)
Scroll up to find a link to hiccup's guide how to override colors for a skin.
sumsi
love your skin but is there any chance the wave bar could be integrated into the player bar by replacing the progress bar, like in the default skin ?
FranciscoM
Yes, please. That would be a great addition 👍🏼
