Author Topic: Regression: #EXTINF title labels not showing again in imported M3U/8 playlists  (Read 1157 times)
This was fixed recently but has now returned, at least since MusicBee version 3.5.8268.
it hasnt been changed. Are they radio stations? Perhaps you could post the m3u playlist so i can try myself
Hi Steven:  below is the content of a "sample.m3u8".  When using File/Playlists/Import Playlists, the file imports but only the web addresses are shown in the entries.  I realize the #EXTINF header on these include a path to an image (not relevant), but the genre title that follows had been displayed by MB in the Title column in "Tracks" display mode; not so in 3.5.8268:
#EXTM3U
#EXTINF:-1 tvg-logo="http://radcap.ru/stylegraf/afrobeat1.jpg",AFROBEAT / AFROBEATS
http://79.120.39.202:8004/afrobeat
#EXTINF:-1 tvg-logo="http://radcap.ru/stylegraf/americana1.jpg",AMERICANA / AMERICAN ROOTS MUSIC
http://213.141.131.10:8004/americana
#EXTINF:-1 tvg-logo="http://radcap.ru/stylegraf/andean.jpg",ANDEAN / SOUTH AMERICAN MUSIC
http://213.141.131.10:8004/andean
#EXTINF:-1 tvg-logo="http://radcap.ru/stylegraf/balkan.jpg",BALKAN MUSIC
http://79.120.39.202:8004/balkan
#EXTINF:-1 tvg-logo="http://radcap.ru/stylegraf/caucasus1.jpg",CAUCASIAN MUSIC
http://213.141.131.10:8004/caucasus
#EXTINF:-1 tvg-logo="http://radcap.ru/stylegraf/celtic1.jpg",CELTIC MUSIC / CELTIC FUSION
http://79.111.14.76:8004/celtic
#EXTINF:-1 tvg-logo="http://radcap.ru/stylegraf/eurofolk.jpg",EUROPEAN / WESTERN FOLK MUSIC
http://213.141.131.10:8004/europeanfolk
#EXTINF:-1 tvg-logo="http://radcap.ru/stylegraf/fado4.jpg",FADO (PORTUGUESE MUSIC)
http://213.141.131.10:8004/fado
i dont think that would have ever worked as it cant parse the tvg-logo. If that is valid formatting then i will need to enhance the parser
When I use this sample exported from another player then imported into MB that is stripped of the svg image data and looks like this:
#EXTM3U
#EXTINF:-1,60's MUSIC COLLECTION
http://213.141.131.10:8004/60collection
#EXTINF:-1,70's MUSIC COLLECTION
http://213.141.131.10:8004/70collection
#EXTINF:-1,80's MUSIC COLLECTION
http://79.120.39.202:8004/pop80
#EXTINF:-1,90's MUSIC COLLECTION
http://213.141.131.10:8004/90collection
#EXTINF:-1,2000's MUSIC COLLECTION
http://79.120.12.130:8004/00collection
#EXTINF:-1,ABSTRACT / EXPERIMENTAL HIP-HOP
http://79.111.14.76:8004/abstracthiphop
I still get a display in MB that looks like this:
Prior to this, the #EXTINF title would appear as "Title", not the stream's URL.  Can you try this sample please?
FWIW I have MB set to import playlists as MBP files, but that's the way I've always had it.
Last Edit: August 23, 2022, 12:54:31 AM by sveakul
I rolled back to 3.5.8267 from my backup, and the sample imported and displayed fine.  I'll stick with that version until I have more time for testing.  Thanks.  Could deleting WebCache.mbl and allowing it to rebuild have caused any problem?  Only thing I can remember doing between versions.
are you sure you are testing with the right file? I didnt make any changes between 3.5.8267 and later versions for playlist parsing and as mentioned the last playlist you sent works fine, using the last published musicbee.exe works fine
I just re-updated to 3.5.8269, and now everything is fine!  Man I don't know, I guess I COULD have been testing the wrong file, or had some timing issue before between deleting the webcache.mbl and adding/deleting.  Just another advertisement to the benefit of keeping backups.  Thanks for bearing with me on this to a successful conclusion.
Last Edit: August 23, 2022, 05:52:32 AM by sveakul
