Author Topic: Duplicate tracks automatically removed upon importing playlist  (Read 583 times)
Treeds
Hi!
I recently upgraded my MusicBee to version 3.5.8249 and I'm having a bit of trouble adapting to a few of the changes, now everytime I import a playlist into MusicBee, all the duplicate tracks from that playlist are automatically gone and it's not really what I want, so I wanted to ask, is there a way I can import a playlist without having duplicates automatically removed like previous versions did?
Thank you so much
what steps do you take to import a playlist? and when you say import a playlist, do you mean add it to an existing playlist?
Last Edit: August 21, 2022, 05:16:04 AM by Steven
Treeds
So, when I edit my playlists I usually edit the amount of each track I want on excel, then save them to a notepad file saved .m3u
Then I use File > Playlists > Import Playlists... to add that file to MusicBee
The import works fine and tracks are added correctly, just not at the count that I chose like it used to be, but just one of each instead
this is what it looks like on notepad, it adds to the amount of 9653 tracks
and this is what it looks like after imported into musicbee with only one of each track
thanks a lot
In Notepad it looks like you're adding the same track multiple times. Is that correct?
And you want multiple copies of the same track in the same playlist. Is that correct?
Why?
Treeds
Yes, that's correct.  It's just the way I listen to music, I add tracks multiple times depending on how much I like them, create a huge playlist and then shuffle them and listen to them for days
Treeds
 it's solved, thank you, thank you so much, I really appreciate it ♥
Música
Interesting strategy...
Great work, response, Sir Steven!
