Author Topic: Equalizer: On vs. Off....? comparison  (Read 372 times)
jlm86
i usually listen to the EQ settings of Rock, and its been fine.....
I notice IF I disable the EQ (un-check) the audio sounds awful....
thoughts ?
thank you
You have conditioned yourself to expect / enjoy whatever frequency curve you have created using the EQ, or your equipment is very poor, but probably some combination of the two.
jlm86
I see these songs are from .m4a files...... I must check the plug-in, as i downloaded that long ago
thank you
