Author Topic: Double click album in Artist view just opens a new window with just that album.  (Read 1106 times)
Tjoeker
Previously when I double clicked an album in this mode, it queued the album last as intended.
Now it just opens a new window with just this album. Worse, double clicking that album opens yet another window with the album displayed in a different style. (at which point double clicking finally queues it)
In the Preferences -> Now Playing -> action when double click is still set at Queue Last.
What other setting do I need to change to get the old back?  :(
Tjoeker
I have 'directly under the selected album or artist' checked, and this works perfectly if I single click the album.
Tjoeker
I did enable and then disable 'show "click to play" button when mouse is over a picture', and kinda assume this is the cause. So it may well be a bug?
can you post a screenshot of the Preferences/ Now Playing window
and also the Artwork panel preferences like the one hiccup showed
edit:
actually could you send me a link to your settings file (help/ support/ view settings)
Last Edit: August 11, 2022, 09:27:52 AM by Steven
Tjoeker
Here you go:
I don't see an attachment option on the forum, so I'll share it using OneDrive:
https://1drv.ms/u/s!AhJDUU3_bBNkpMd4lcaKcSa1fsTbfg?e=9zLoJ1
Let me know if you'd prefer a different sharing method. :)
in your settings file 'drill down in a separate panel' is ticked, so double clicking will not play the tracks and instead open a new panel
Tjoeker
Do you know where that setting is? In any 'customize panel' I try, it has 'directly under the selected album' selected instead of drilldown.
If the settings file indeed says something different then what I selected, then I assume it fails to save that setting?  :)
edit:
3.5 fixed the issue indeed, it now shows the setting that is consistent with what you say is in the settings file.
