Author Topic: MusicBee update messed up my library. Help!  (Read 640 times)
Sequence334
Hi, I've been an avid MusicBee user for about 5 years now, but it is until today that I made a forum account since I've encountered my first real issue with the application. I wanted to try the newest DiscordBee plugin but it kept telling me to update MusicBee in order to use the plugin, which I did. I believe I hadn't updated since early 2020, and I snagged the latest experimental version of MusicBee (3.5.8150), which I think was my mistake instead of installing the latest official stable release. Everything's fine, the plugin works correctly and all, but my library is all messed up, with album songs splitting in different parts and not being in alphabetical order, strangely enough this only happens in the "Album covers" view, as all the other views are fine. Any help?
Last Edit: August 04, 2022, 09:25:07 PM by Sequence334
check the sorting you are using for the panel and also the grouping
Sequence334
Oh I'm a total idiot, I forgot to check that. That fixed it. Thank you Steven!
