Hi, is there a way to create an option, perhaps via settings.ini, to have LyricsReloaded check the "mark as having no lyrics" box when no lyrics are found? I assume this would just be setting a tag value, though I'm not sure what the tag is or what the value is.
The main purpose of this feature would be to prevent unnecessary duplicate checking for lyrics when playing a file multiple times with automatic lyrics download enabled.
Also, this is a really minor aside, but the readme.txt for the current version has an incorrect path for where to place the providers files. I believe it should be: %AppData%\MusicBee\mb_LyricsReloaded\providers, but the readme has an extra \AppData\ between the MusicBee and the mb_LyricsReloaded. I figured out the problem pretty quickly, but I could see this vexing some users.
Another mostly-irrelevant aside: let me mention, removing the old version 1.2.0.5 was an absolute beast of a problem, and I think it's because I have the "app" version of MusicBee, which means there's nothing to find in Program Files or Program Files (x86). If anyone else is having difficulty, here was my solution: I finally searched my entire drive for "MusicBee" and deleted everything I could find in subfolders of the Users folder, except for the contents of %AppData%\Roaming\MusicBee. Then I manually copied the new mb_LyricsReloaded.dll file into its proper position in %AppData%\Roaming\MusicBee\plugins and ran MusicBee. In doing this, I lost all my settings, but it did fix the weird uninstall errors and let me uninstall and then properly reinstall Lyrics Reloaded 1.2.0.7. Also, this caused MusicBee to create new settings files in %AppData%\Roaming\MusicBee that weren't there before.
