Author Topic: LyricsReloaded (Latest)  (Read 62774 times)
  • Heal The World
Hello Corliss Rain.
Are you using the latest 1.1.16.6 plugin version?
Is there anything in the plugin's error log? You can find the file in this folder: ...\MusicBee\AppData\mb_LyricsReloaded
I'm getting this system error and then MB shuts down. Help!
MusicBee v3.5.8292.34303D  (Win10.0), 29 Sep 2022 12:39:
   at CubeIsland.LyricsReloaded.LyricsReloaded.shutdown()
   at CubeIsland.LyricsReloaded.LyricsReloaded.Finalize()
You may have more than one instance of the plugin on your computer, or the plugin is not located where MusicBee expects to find it, i.e. in the MusicBee/Plugins folder.
aktor
The plugin doesn't find the lyrics from metal archives even though the are there.
30.09.2022 12:11:50 [DEBUG] Lyrics request: Strigoi - Bathed In A Black Sun - Viscera - Metal Archives
30.09.2022 12:11:50 [INFO] Metal Archives tries to load the lyrics...
30.09.2022 12:11:50 [DEBUG] The constructed google identity URL: https://www.google.com/search?q=Metal Archives+Strigoi+Bathed In A Black Sun+Viscera
30.09.2022 12:11:51 [DEBUG] The constructed identity URL: https://www.metal-archives.com/albums/Strigoi/Viscera/1057366
Deezer the same
30.09.2022 12:16:47 [DEBUG] Lyrics request: Björk - Army Of Me - Post - Deezer
30.09.2022 12:16:47 [INFO] Deezer tries to load the lyrics...
30.09.2022 12:16:47 [DEBUG] The constructed identity URL: https://www.google.com/search?q=Deezer+army of me+björk
30.09.2022 12:16:48 [DEBUG] The constructed lyrics URL: https://www.deezer.com/en/track/510168672
  • Heal The World
Trying it out now, both requests are giving me (correct) results.
Can you untick the other providers and then retry Metal Archives and Deezer one at a time.
If they fail for the same songs, post the log entries again for each of them.
It's easier to follow the log file when it's searching from one provider at a time.
The entries you have posted above are missing a couple of lines.
aktor
It is done that way. For strigoi I checked only metal archives and for Bjork deezer. Plugin (1.1.16.6) and MB (3.5.8302) is up to date i think.
  • Heal The World
Do you get the same log entries when you redo the search for each of the providers at a single time?
A full successful Metal Archives log entry will look like this:
30-09-2022 04:04:45 [DEBUG] Lyrics request: Strigoi - Bathed In A Black Sun - Viscera - Metal Archives
30-09-2022 04:04:45 [INFO] Metal Archives tries to load the lyrics...
30-09-2022 04:04:45 [DEBUG] The constructed google identity URL: https://www.google.com/search?q=Metal Archives+Strigoi+Bathed In A Black Sun+Viscera
30-09-2022 04:04:47 [DEBUG] The constructed identity URL: https://www.metal-archives.com/albums/Strigoi/Viscera/1057366
30-09-2022 04:04:48 [DEBUG] The constructed lyrics URL: https://www.metal-archives.com/release/ajax-view-lyrics/id/6380887
30-09-2022 04:04:49 [SUCCESS] lyrics found from Metal Archives!
aktor
0.09.2022 05:38:06 [DEBUG] Lyrics request: Strigoi - Bathed In A Black Sun - Viscera - Metal Archives
30.09.2022 05:38:06 [INFO] Metal Archives tries to load the lyrics...
30.09.2022 05:38:06 [DEBUG] The constructed google identity URL: https://www.google.com/search?q=Metal Archives+Strigoi+Bathed In A Black Sun+Viscera
30.09.2022 05:38:08 [DEBUG] The constructed identity URL: https://www.metal-archives.com/albums/Strigoi/Viscera/1057366
This is what i get.
and the following are missing
Last Edit: September 30, 2022, 04:53:29 PM by aktor
  • Heal The World
I'm not entirely sure why the last search is not being conducted on your side. It may be that your IP has been temporary banned on the Metal Archives website.
That tends to happen after a while when you've repeatedly used the same provider. Does it also fail when you try with other songs from that website?
Also, there was a recent change that I made to the Metal Archives yml. Try grabbing the latest one from the providers zip (but I suspect that's the one you already have)
And what about Deezer? Is it also still failing and producing the same log entries?
aktor
When all boxes are checked I get the lyrics. This is the log.
30.09.2022 05:42:29 [DEBUG] Lyrics request: Björk - Hunter - Homogenic - Musixmatch
30.09.2022 05:42:29 [INFO] Musixmatch tries to load the lyrics...
genic - Musixmatch
earch.php?q=björk+hunter
jörk+Hunter+Homog30.09.2022 05:42:29 [INFO] Musixmatch tries to load the lyrics...
genic - Musixmatch
jörk+Hunter+Homog30.09.2022 05:42:29 [DEBUG] The constructed URL: https://genius.com/bjork-hunter-lyrics
30.09.2022 05:42:29 [DEBUG] The constructed URL: http://www.musixmatch.com/lyrics/bjork/hunter
30.09.2022 05:42:29 [DEBUG] The constructed lyrics URL: https://www.lyricsfreak.com/b/bjork/hunter_20018853.html
30.09.2022 05:42:32 [WARN] The google identity pattern (?<identity>https://www.metal-archives.com/albums/Björk/.*?)["&] didn't match!
30.09.2022 05:42:32 [FAIL] no lyrics found from Metal Archives
30.09.2022 05:42:32 [DEBUG] Received a notification of type TagsChanging
Access to the Metal Archives site is blocked in Russia (https://forum.metal-archives.com/viewtopic.php?f=3&t=131317), about Deezer I don't know.
aktor
It is not that M Archives a accessible just fine.
  • Heal The World
You never gave answers to some of the questions.
Is Metal Archives not working for any of your tracks (ones you know are present on their website)?
Has this provider ever worked for you before, or you had just installed the plugin and realized that MA wasn't getting you any lyrics?
Is Deezer still not getting you the lyrics for Björk's Army of Me?
If it still isn't, can you also check whether or not it's getting lyrics for any of your other tracks.
And remember to do your testing one provider (MA and Deezer) at a time.
aktor
Is Metal Archives not working for any of your tracks (ones you know are present on their website)? - Positive
Has this provider ever worked for you before, or you had just installed the plugin and realized that MA wasn't getting you any lyrics? I just installed the plugin and realized that MA wasn't getting any lyrics.
Is Deezer still not getting you the lyrics for Björk's Army of Me? Deezer not working.
If it still isn't, can you also check whether or not it's getting lyrics for any of your other tracks? Not working
1.10.2022 09:26:43 [DEBUG] Lyrics request: Radiohead - Creep - Pablo Honey - Deezer
01.10.2022 09:26:43 [INFO] Deezer tries to load the lyrics...
01.10.2022 09:26:43 [DEBUG] The constructed identity URL: https://www.google.com/search?q=Deezer+creep+radiohead
01.10.2022 09:26:45 [DEBUG] The constructed lyrics URL: https://www.deezer.com/en/track/138547415
also genius doesn't work
01.10.2022 09:28:53 [DEBUG] Lyrics request: Radiohead - Creep - Pablo Honey - Genius
01.10.2022 09:28:53 [INFO] Genius tries to load the lyrics...
01.10.2022 09:28:53 [DEBUG] The constructed URL: https://genius.com/radiohead-creep-lyrics
but chartlylirics works
and thanks for the antwers
aktor
I deleted and reinstalled the plugin. now zje strang things i that it works except for the band stigoi (lyrics are on metal archives site)
log:
01.10.2022 09:51:34 [DEBUG] Lyrics request: Amorphis - My Kantele - My Kantele - Genius via Beenius
01.10.2022 09:51:34 [WARN] The provider Genius via Beenius was not found!
01.10.2022 09:51:37 [DEBUG] Received a notification of type TagsChanging
01.10.2022 09:51:56 [DEBUG] Received a notification of type TagsChanging
01.10.2022 09:51:56 [DEBUG] Lyrics request: Amorphis - My Kantele - My Kantele - Deezer
01.10.2022 09:51:56 [INFO] Deezer tries to load the lyrics...
01.10.2022 09:51:56 [DEBUG] The constructed identity URL: https://www.google.com/search?q=Deezer+my kantele+amorphis
01.10.2022 09:51:57 [DEBUG] The constructed lyrics URL: https://www.deezer.com/en/track/10970713
01.10.2022 09:52:01 [DEBUG] Received a notification of type TagsChanging
01.10.2022 09:52:28 [DEBUG] Received a notification of type TagsChanging
01.10.2022 09:52:28 [DEBUG] Lyrics request: Amorphis - My Kantele - My Kantele - Genius
01.10.2022 09:52:28 [INFO] Genius tries to load the lyrics...
01.10.2022 09:52:28 [DEBUG] The constructed URL: https://genius.com/amorphis-my-kantele-lyrics
01.10.2022 09:52:30 [SUCCESS] lyrics found from Genius!
01.10.2022 09:52:30 [DEBUG] Received a notification of type TagsChanging
01.10.2022 09:52:53 [DEBUG] Received a notification of type TagsChanging
01.10.2022 09:52:53 [DEBUG] Lyrics request: Amorphis - My Kantele - My Kantele - Metal Archives
01.10.2022 09:52:53 [INFO] Metal Archives tries to load the lyrics...
01.10.2022 09:52:53 [DEBUG] The constructed google identity URL: https://www.google.com/search?q=Metal Archives+Amorphis+My Kantele+My Kantele
01.10.2022 09:52:54 [DEBUG] The constructed identity URL: https://www.metal-archives.com/albums/Amorphis/My_Kantele/5599
01.10.2022 09:52:57 [DEBUG] Received a notification of type TagsChanging
01.10.2022 09:54:48 [DEBUG] Received a notification of type TagsChanging
01.10.2022 09:54:52 [DEBUG] Received a notification of type TagsChanging
01.10.2022 09:54:52 [DEBUG] Lyrics request: Amorphis - My Kantele - My Kantele - Metal Archives
01.10.2022 09:54:52 [INFO] Metal Archives tries to load the lyrics...
01.10.2022 09:54:52 [DEBUG] The constructed google identity URL: https://www.google.com/search?q=Metal Archives+Amorphis+My Kantele+My Kantele
01.10.2022 09:54:53 [DEBUG] The constructed identity URL: https://www.metal-archives.com/albums/Amorphis/My_Kantele/5599
01.10.2022 09:54:56 [DEBUG] Received a notification of type TagsChanging
01.10.2022 09:55:14 [DEBUG] Received a notification of type TagsChanging
01.10.2022 09:55:18 [DEBUG] Received a notification of type TagsChanging
01.10.2022 09:55:23 [DEBUG] Lyrics request: Strigoi - King Of All Terror - Viscera - Metal Archives
01.10.2022 09:55:23 [INFO] Metal Archives tries to load the lyrics...
01.10.2022 09:55:23 [DEBUG] The constructed google identity URL: https://www.google.com/search?q=Metal Archives+Strigoi+King Of All Terror+Viscera
01.10.2022 09:55:24 [DEBUG] The constructed identity URL: https://www.metal-archives.com/albums/Strigoi/Viscera/1057366
01.10.2022 09:55:29 [DEBUG] Lyrics request: Strigoi - Byzantine Tragedy - Viscera - Metal Archives
01.10.2022 09:55:29 [INFO] Metal Archives tries to load the lyrics...
01.10.2022 09:55:29 [DEBUG] The constructed google identity URL: https://www.google.com/search?q=Metal Archives+Strigoi+Byzantine Tragedy+Viscera
01.10.2022 09:55:31 [DEBUG] The constructed identity URL: https://www.metal-archives.com/albums/Strigoi/Viscera/1057366
01.10.2022 09:55:49 [DEBUG] Lyrics request: Strigoi - The Rising Horde - Abandon All Faith - Metal Archives
01.10.2022 09:55:49 [INFO] Metal Archives tries to load the lyrics...
01.10.2022 09:55:49 [DEBUG] The constructed google identity URL: https://www.google.com/search?q=Metal Archives+Strigoi+The Rising Horde+Abandon All Faith
01.10.2022 09:55:50 [DEBUG] The constructed identity URL: https://www.metal-archives.com/albums/Strigoi/Abandon_All_Faith/807099
01.10.2022 09:57:44 [DEBUG] Lyrics request: Deathspell Omega - Enantiodromia - The Long Defeat - Metal Archives
01.10.2022 09:57:44 [INFO] Metal Archives tries to load the lyrics...
01.10.2022 09:57:44 [DEBUG] The constructed google identity URL: https://www.google.com/search?q=Metal Archives+Deathspell_Omega+Enantiodromia+The Long Defeat
01.10.2022 09:57:46 [DEBUG] The constructed identity URL: https://www.metal-archives.com/albums/Deathspell_Omega/The_Long_Defeat/1025837
01.10.2022 09:57:47 [DEBUG] Received a notification of type TagsChanging
  • Heal The World
Glad to hear that a simple reinstall fixed most of yesterday's problems.
Did you get the lyrics for these two tracks?
If you did not, then you must have some kind of issue with the MA website (probably along the lines of what sveakul mentioned) that I wouldn't be able to help with.
But if you did get the lyrics for those two, then I honestly do not know why the Strigoi tracks would not work for you.
On my side, I'm getting results for all those Strigoi tracks except for The Rising Hordes which is an instrumental.
