Yes, I would really like to have both versions because for hip hop music I prefer the names of the singers. If you can also make a fuzzy version apart from the normal one I would appreciate it so I will have all 4 versions:
- Genius
- Genius headers
- Genius (fuzzy)
- Genius headers (fuzzy)
Man you don't ask for much. As Mayibongwe pointed out the current behavior of not including bracketed text was requested and has been appreciated by others for years now. None of these patterns produce perfect results for all titles, that's just a fact we accept in an inexact science. I (and others) would be opposed to changing the current compromise unless presented as an OPTION that can be toggled on or off by the user, as opposed to having our Providers folder and search order lists filled up by 4 different versions of the same thing.
BTW, the Beenius plugin, which searches only Genius and via an improved API method, has had the ability to exclude bracketed title text since practically day one, by making a change to one of its *.conf file values (titleTrim). You should read up on its installation and options here and use it :
https://github.com/slonopot/Beenius . BOTH BEENIUS AND LYRICS RELOADED CAN BE USED AT THE SAME TIME.
