Author Topic: Search looking for album covers whose resolution is less than...  (Read 761 times)
Will Pittenger
It'd be useful to have a search for album covers that are either missing or of a resolution less than a specified amount.
Will Pittenger
Have a look at Tools > Artwork > Album Artwork Manager....
I'm not sure how long this has been around, so you might want to update to the latest version of MusicBee before diving in.
Will Pittenger
That window doesn't open for me.  I'm pretty sure I have the latest version now.  Windows 11 Pro.
Will Pittenger
What version of MB are you using? (Help > About) INCLUDE THE LETTER (if any) AFTER THE NUMBER
Will Pittenger
It shows 3.5.8150, no letter.  I believe this profile was installed from an installer.
Will Pittenger
.8150 is from late April. Many fixes/improvements since then. I suggest updating to the latest patch. See my signature. Although I don't recall any issues with the Artwork manager that would've been fixed in the latest patch. Perhaps a reinstall of MB is needed.
The Album Artwork Manager seems to work on the tracks currently displayed in the main window, so make sure you run the command from an actual library view, not something like the Music Explorer.
