Author Topic: Refresh scrobble data  (Read 1698 times)
heyman111
Last.fm allows users who pay for pro to change the metadata of previous scrobbles.
This poses a problem when using musicbee since it goes through and saves(/caches?) data only one time.
Would be nice for it to force a new refresh of the saved data with the click of a button
You can delete the file LastFmPlayCountCache.dat to refresh the data.
It is in Internal Cache folder under the Main Settings folder (here's an excellent reference on where to find that depending on your MB version).
heyman111
Yes I know but it would be way easier and more convenient to have it in the UI to do this instead.
The Incredible Boom Boom
This would be a good idea to add to the interface. + 1
  • Heal The World
Deleting this file by means of a plugin hotkey or toolbar button would be easy enough to do.
Is this something that would suffice? One would expect so, but some users prefer to have the official MB stamp on a feature as opposed to user-provided plugins.
So would like to know before putting any effort (as little as it may be) to it.
Strength and Honour (2025)
