Author Topic: Help MB is doing a background task and I cannot stop it !  (Read 257 times)
zpoison
Please help I don't know what MB is doing but I cannot close or change library
It says "THE LIBRARY CANNOT BE CHANGED WHILE BACKGROUND TASKS ARE RUNNING."
It also says it is running a background task when I try to close it to end this nightmare
Last Edit: July 12, 2022, 03:14:58 AM by zpoison
when you attempt to close MB a question is asked to confirm and you can answer so it closes anyway
Also on the status bar an X should display on the left side of the status bar. Just click it to abort the running process
