Author Topic: Spontaneous errors / playback continues, but no more access to MB  (Read 1096 times)
YannigVdW
  • Fruit flies like a banana.
These errors happen seemingly random during playback. I guess I have them maybe three times a day.
MusicBee v3.4.8033.18564D  (Win10.0), 8 jul 2022 8:36:
System.ObjectDisposedException: Geen toegang tot een verwijderd object.
Objectnaam: #=zeOxXoEsAAtJ0.
   bij System.Windows.Forms.Control.CreateHandle()
   bij System.Windows.Forms.Control.get_Handle()
   bij System.Windows.Forms.Control.GetSafeHandle(IWin32Window window)
   bij System.Windows.Forms.ToolTip.Hide(IWin32Window win)
   bij System.Windows.Forms.ToolTip.TimerHandler(Object source, EventArgs args)
   bij System.Windows.Forms.Timer.OnTick(EventArgs e)
   bij System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
   bij System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
When I click ok, the message disappears briefly, and then returns.
I have to close MB to resume playback without errors.
can you send a link to your settings file (help/ support/ view settings)
thanks for sending the settings file.
According to the log, the error is occurring with either a dedicated artist picture panel or dedicated album picture panel. However neither is configured to be displayed in your settings file. So perhaps you are changing the configuration to show either panel?
YannigVdW
Thanks for looking into this ;)
I'm almost always in the Now Playing panel. I'm not sure I've changed something to the layout. Here are my Layout preferences:
I'm not sure how I should configure the layout from the preferences now that I look into it :)
YannigVdW
YannigVdW
that doesnt correspond to the settings file you sent
Ok 🤷‍♂️ 😂
What does that mean, and what can I do?  :)
i am not sure what happened but i redownloaded the settings file and now it looks like your screenshot
The issue will be related to either the artist or album picture in the Now Playing tab and probably related to the tooltip that shows. However i cant reproduce any issues.
I have made a guess what the issue might be so could you try this version:
YannigVdW
FYI, since I'm using this version, I haven't had a single crash. So many thanks for that ;)
