Author Topic: Sync last.fm playcount only for selected files, or replace whole album files  (Read 1230 times)
pakk
Hi
I'd like to be able to sync last.fm playcount only for selected file.
Use case:
Let's say I have an album in .mp3 that I've already played lots of times.
Let's say I reencode it in .m4a and add it to my library: unless I'm replacing files for each track individually, which can be very tedious, I will lose all the playcount and last played data.
So, as a fix, I thought syncing last.fm playcount could do the trick.
But if there's a solution for my initial problem, i.e. the ability to replace a whole album files at once, that would be great too.
When I replace albums with a different format, I use the copy tags to clipboard / paste tags from clipboard feature in the Additional Tagging Tools plugin to copy this kind of information from one set to the other in bulk.  You can even have a number of different sets of tags for different purposes.
pakk
pakk
I've tried the copy/paste tags like you said, and that's exactly what I needed ! You rock !
Thanks a lot for the help, have a great day !
Last Edit: July 20, 2022, 09:38:56 PM by pakk
I've tried the copy/past tags like you said, and that's exactly what I needed ! You rock !
Glad to help.
