Author Topic: Gnudb  (Read 776 times)
gnudb
Use correct version when quering gnudb.gnudb.org, fix the replicated POST to gnudb.org. The version is used to blok defective program version (3.4 is quering as 1.0.0) . 1.0.0 is a candidate to be blocked due to the load when it is posting the same data in very short time.
[24/Jun/2022:22:58:30 +0200] "POST /~cddb/cddb.cgi HTTP/1.1" 200 65 "-" "MusicBee/3.4" [cmd=cddb+query+5b0aa508+8+150+25469+46546+89014+114839+138112+168279+184775+2727&hello=unknown+unknown+unknown+1.0.0&proto=6]
[24/Jun/2022:22:58:31 +0200] "POST /~cddb/cddb.cgi HTTP/1.1" 200 65 "-" "MusicBee/3.4" [cmd=cddb+query+5b0aa508+8+150+25469+46546+89014+114839+138112+168279+184775+2727&hello=unknown+unknown+unknown+1.0.0&proto=6]
[24/Jun/2022:22:58:32 +0200] "POST /~cddb/cddb.cgi HTTP/1.1" 200 65 "-" "MusicBee/3.4" [cmd=cddb+query+5b0aa508+8+150+25469+46546+89014+114839+138112+168279+184775+2727&hello=unknown+unknown+unknown+1.0.0&proto=6]
[24/Jun/2022:22:58:33 +0200] "POST /~cddb/cddb.cgi HTTP/1.1" 200 65 "-" "MusicBee/3.4" [cmd=cddb+query+5b0aa508+8+150+25469+46546+89014+114839+138112+168279+184775+2727&hello=unknown+unknown+unknown+1.0.0&proto=6]
[24/Jun/2022:22:58:34 +0200] "POST /~cddb/cddb.cgi HTTP/1.1" 200 65 "-" "MusicBee/3.4" [cmd=cddb+query+5b0aa508+8+150+25469+46546+89014+114839+138112+168279+184775+2727&hello=unknown+unknown+unknown+1.0.0&proto=6]
[24/Jun/2022:22:58:35 +0200] "POST /~cddb/cddb.cgi HTTP/1.1" 200 65 "-" "MusicBee/3.4" [cmd=cddb+query+5b0aa508+8+150+25469+46546+89014+114839+138112+168279+184775+2727&hello=unknown+unknown+unknown+1.0.0&proto=6]
[24/Jun/2022:22:58:36 +0200] "POST /~cddb/cddb.cgi HTTP/1.1" 200 65 "-" "MusicBee/3.4" [cmd=cddb+query+5b0aa508+8+150+25469+46546+89014+114839+138112+168279+184775+2727&hello=unknown+unknown+unknown+1.0.0&proto=6]
[24/Jun/2022:22:58:37 +0200] "POST /~cddb/cddb.cgi HTTP/1.1" 200 65 "-" "MusicBee/3.4" [cmd=cddb+query+5b0aa508+8+150+25469+46546+89014+114839+138112+168279+184775+2727&hello=unknown+unknown+unknown+1.0.0&proto=6]
[24/Jun/2022:22:58:38 +0200] "POST /~cddb/cddb.cgi HTTP/1.1" 200 65 "-" "MusicBee/3.4" [cmd=cddb+query+5b0aa508+8+150+25469+46546+89014+114839+138112+168279+184775+2727&hello=unknown+unknown+unknown+1.0.0&proto=6]
[24/Jun/2022:22:58:39 +0200] "POST /~cddb/cddb.cgi HTTP/1.1" 200 65 "-" "MusicBee/3.4" [cmd=cddb+query+5b0aa508+8+150+25469+46546+89014+114839+138112+168279+184775+2727&hello=unknown+unknown+unknown+1.0.0&proto=6]
[24/Jun/2022:22:58:40 +0200] "POST /~cddb/cddb.cgi HTTP/1.1" 200 65 "-" "MusicBee/3.4" [cmd=cddb+query+5b0aa508+8+150+25469+46546+89014+114839+138112+168279+184775+2727&hello=unknown+unknown+unknown+1.0.0&proto=6]
I cant actually reproduce the repeated query behavior, but i have put in a throttle to prevent quick re-querying and corrected the version number on the post message. If you could confirm its ok now before the update is made available, it would be appreciated
unzip and replace the existing musicbee.exe
gnudb
I am maintaining gnudb.org, I am not using MusicBee so i do not have the possibility to test it. I do not know if it is possible for the user to use a valid email address, as the mail address will be used to block the gnudb service on a user level, if the use is not appropriate.
