Author Topic: any 3.5 patch after 3.5.8155.33067  (Read 2018 times)
  • MB Version: 3.6.9255 P
When I apply any patch after 3.5.8155 P, on restart MB is back on the setup screen
on hitting Next, MB crashes displays this
and shows the error log
25/06/2022 8:29:18 AM - 10.0.19044.0 - 3.5.8155.33067P - System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.IO.DirectoryNotFoundException: Could not find a part of the path 'T:\MusicBee\AppData\ScrobblerBrainz\scrobbles'.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.FileSystemEnumerableIterator`1.CommonInit()
   at System.IO.FileSystemEnumerableIterator`1..ctor(String path, String originalUserPath, String searchPattern, SearchOption searchOption, SearchResultHandler`1 resultHandler, Boolean checkHost)
   at System.IO.Directory.GetFiles(String path)
   at MusicBeePlugin.Plugin.ReceiveNotification(String sourceFileUrl, NotificationType type)
   at #=zqR2XciUj1qIekb1OHQ==.#=zbyPRNJ_M2OXp()
25/06/2022 8:31:31 AM - 10.0.19044.0 - 3.5.8155.33067P - System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.IO.DirectoryNotFoundException: Could not find a part of the path 'T:\MusicBee\AppData\ScrobblerBrainz\scrobbles'.
25/06/2022 8:34:05 AM - 10.0.19044.0 - 3.5.8210.27933P - System.NullReferenceException: Object reference not set to an instance of an object.
   at #=zk5SEiqZCqE4YlPugON748uI=.#=zwDe5Z7I=(TagCode #=zVsPzGb0=)
   at #=z$esw0fmjBKbzoJMJSzCRYLI=.#=z1r6e0L$rlXggaQPHgw==()
   at #=zyH0Dou9xnMfGH9Hd3VArX5FLYQiH.#=zXpWp4Zg=(String #=zVsPzGb0=, List`1 #=zkIoSE4M=, Boolean #=z$prR_NkWN81h)
   at #=zkmoYrZbkWRKgdIjGsfAf8afui5Dz.#=z0OATpW8_LyKv.#=qlnonNVBfIhD$A4bKZD0rog==._Lambda$__0()
   at #=zkmoYrZbkWRKgdIjGsfAf8afui5Dz.#=z0OATpW8_LyKv.#=z59X9j9U=(#=zyH0Dou9xnMfGH9Hd3VArX5FLYQiH #=znys0hHJeTTRL)
   at #=zkmoYrZbkWRKgdIjGsfAf8afui5Dz.#=z59X9j9U=(#=zyH0Dou9xnMfGH9Hd3VArX5FLYQiH #=znys0hHJeTTRL, #=zhlHDIq6oQPlc_cO$EBTRcVI4s3v3 #=zcOWH7Do=)
   at #=zm$nd6O9N5iV4FRzQov7Gfuo=.#=zYAdnK6Th9XvY(#=zqvQjSifVESg33TjT9g== #=zjrvUNUTOuQSE, String #=zZVao4xs=)
   at #=zm$nd6O9N5iV4FRzQov7Gfuo=.#=zSOqKdk_qh9vF()
25/06/2022 8:34:23 AM - 10.0.19044.0 - 3.5.8210.27933P - System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at #=z0bxYpnrivygbATNlmv1mg5E=.#=z1ABCvLvu7H_c.#=zFy2InU4=(String #=zG_Tcx70=)
   at #=z0bxYpnrivygbATNlmv1mg5E=.#=zVwuPli5u3rfD(TagCode #=zVsPzGb0=, String #=zG_Tcx70=)
   at #=z9wQ69WuqA4_JSgwWLVPFZkk=.#=zEMP9cnpO$qua.#=zMyrpsBcEdlOX(BinaryReader #=zS_673sw=, #=z0bxYpnrivygbATNlmv1mg5E= #=zpHJvBOI=)
   at #=z9wQ69WuqA4_JSgwWLVPFZkk=.#=zEMP9cnpO$qua.#=zJbf2E9k=(FileStream #=zOfzqzIM=)
   at #=z9wQ69WuqA4_JSgwWLVPFZkk=.#=zsFkd$FWfEL6L.#=z1r6e0L$rlXggaQPHgw==(#=zqvQjSifVESg33TjT9g== #=zqAVnA4kzA6Mb)
25/06/2022 8:34:23 AM - 10.0.19044.0 - 3.5.8210.27933P - System.IO.InvalidDataException: Files cache 'T:\MusicBee\Library\MusicBeeLibrary.mbl' is corrupted. Suggested action is to delete this file and the .bak file, then restart the application ---> System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at #=z9wQ69WuqA4_JSgwWLVPFZkk=.#=zsn6wEuQi3JXK()
   at #=z7$Jfyt6Qa6sDiJdQ6wJYUPs=.#=zVugWzYA82YRL(#=zIWBPPyP4$1cJPrwZFHfCI7E= #=z3KNRb_k=)
   at #=zhEwU3W9SkdyBdrteIWc$YAiji_I9.Main(String[] args)
I now see that 8155 also threw errors but it never stopped working
the errors you have listed are for a plugin and wont stop mb.
To reach the initial setup screen, no existing settings file could be found or it was corrupted in some way. Do you see any files named: MusicBee3Settings_corrupted_*.* ?
However i would expect any error reading a corrupted settings file to be logged
So does the AppData folder still exist from the location you run MB?
As to the corrupted MusicBeeLibrary.mbl file, if you send it to me i can have a look at whats going on
Yes
Yes
Here is both the corrupted MusicBeeLibrary.mbl and MusicBee3Settings files.
filesharing24.com
when clicking on the link in the filesharing24 site, a 404 error shows
the settings file issue is related to the removal of support for songkick and hence the artist touring field which you had in one of your queries
This fixes that. I couldnt find anything wrong with the library
Perfection!
Thank you Steven.
