Author Topic: Small Playlist Mixer % Issue in 3.5  (Read 1850 times)
Sir Blobspierre
I love the new % feature, but there's a slight bug.
If you make a playlist that includes a criteria with a percentage other than 100%, then the playlist will generate properly. But then if you switch playlists, and switch back, it will only have 1 track from each category with a non-100 percentage.
This is easily fixed by hitting F5 to generate a new list properly.
Coogan
I installed this patch and then got and Out of Range Error in Notepad, when trying to start MusicBee.
I can't send a link to my settings, because I can't start MusicBee.
Here is a link to the Notepad Error and an image of suggested fix.
https://www.mediafire.com/file/kwsg7sizfw9xixh/ErrorLog.dat/file
https://www.mediafire.com/view/fj4wx47ek4d01ac/MusicBee_Startup_Error.png/file
I'm using version 3.5.8150
Last Edit: June 24, 2022, 08:49:02 AM by Coogan
My MusicBee Version:
3.6.9285
Coogan
Hmm, still getting the same errors.
I can restore my PC prior to installing the patch.  I should then be able to open MusicBee to send my Settings.
*Edit:  Here's my Settings file. https://www.mediafire.com/file/mijty6zrfholka0/MusicBee3Settings.ini/file
(note, this is before applying patch)
Last Edit: June 24, 2022, 09:17:10 AM by Coogan
3.6.9285
can you send the last new entries in the error log. Are you sure you replaced musicbee,exe ?
the version should end with .32328
Coogan
That's the only settings file I have.  I did a System Restore on my PC, so that file is from before applying the patch.
I can't open MusicBee after I apply the patch.  So right now I'm back to 3.5.8150
3.6.9285
i dont think you applied the latest patch version.
can you send me the new errors at the end of the error log. The version number in the new errors should end with .32328
Coogan
The only error log I have is the one I linked above.  I have nothing new.
3.6.9285
i dont think i can help you any further with this - if there is nothing new in the error log then no errors are being generated
Coogan
That's my problem.  I can't open MusicBee after installing the patch to get the Error Log.
Thanks for helping though, it's much apperciated.
3.6.9285
- download https://getmusicbee.com/patches/MusicBee35_Patched.zip
- unzip it
- copy musicbee.exe to c:\program files (x86)\musicbee\musicbee.exe
- run musicbee
- if an exception occurs on startup the error log should open in notepad
- if notepad didnt open and musicbee didnt start without an error message being displayed then look in: c:\users\<your id>\appdata\roaming\musicbee\errorlog.dat
Coogan
MusicBee did start without any errors and is now version 3.5.8210
I only moved the .exe file. Should I move all of the other files too?
3.6.9285
Coogan
ok, It's working now.
Thank you very much for your help and patience.  :)
3.6.9285
