Author Topic: iPod & iPhone Driver Plugin 2.0  (Read 37978 times)
BoringName
Recently had 2 songs that wouldn't copy to iTunes. I tried relocating them in Musicbee but it didn't fix it. There didn't seem anything odd about them. The only thing I have just realised is both track titles were only 2 characters long... maybe adding some extra characters might of fixed it.
Anyway, I just opened iTunes separately and added the 2 songs manually. They imported fine so it must be a stupid bug with the iTunes API stopping them importing via the plugin. Now they are in there it will sync play counts back on the next sync.
Nephraxis
I'm currently using MusicBee 3.6.9202 with the Ipod & Iphone driver plugin. I'm using iTunes 12.12.2.2. It's been a while since I last synced with my iphone 13 and I've done it successfully in the past, but now when I turn on the plugin and try to Synchronize, it aborts pretty much immediately with the error message "Length cannot be less than zero.Parameter name: length". Does anyone know how I can fix this?
Last Edit: June 02, 2025, 08:42:37 PM by Nephraxis
BoringName
Sorry I haven't got a lot of free time at the moment.
Best guess is you are trying to sync a playlist that does not contain any tracks, I can see a line in the code that would have problems with an empty playlist.
If that's not the case I'm not sure what else it could be. Maybe try syncing individual playlists and see if that works.
I should have more time in a couple of weeks to troubleshoot properly.
