Author Topic: Lunar Eclipse  (Read 7395 times)
  • Heal The World
This is a replica of my Oblivion skin which features warmer colours.
Download it from the add-on link here.
For the progress bar to be displayed as intended, an update to MB 3.5.8121 or higher is needed.
Strength and Honour (2025)
  • Heal The World
Thanks Boom Boom. Appreciate it.
Down the line, I might give this skin its own progress bar should any ideas pop up in my head.
Is the yellow for previous/next disabled intentional?
  • Heal The World
Nope, not at all, that doesn't look right. I shall correct that.
Crazy how I haven't picked this up given that I use this skin almost as many times as I do the other version.
Thanks hiccup.
Edit: it's just occurring to me that your screenshot is showing the sidebar player - which I never use.
So the other skin probably has this oversight as well (i hope it's not linked to any other control where this kind of colour makes sense).
I will dig into it later this week.
Two other things that you may want to check then is the 'loved' icon not doing much in the compact player.
(in the mini player it could probably also be a bit lighter, so to match the rating stars?)
And time/duration can get overlapped by the progressbardots:
