Author Topic: Artist grouping  (Read 551 times)
niroooo
Why is the same artist sometimes grouped multiple times within the Albums & Tracks view? The Album and Album Artist tags are identical. Is something else causing this?
For example:
Samaris
Album: Black Lights
Samaris
Album: Silkidrangar
Album: Samaris (self-titled)
If you look at your customize panel settings (which is in the menu under "Album and Tracks"), is there anything in the right grouping field? If any of the grouping headers change it will create a new group.
If not that, then can you select all the tracks and post a screenshot of the tag editor?
niroooo
Spot on!
I had "Rating" enabled in the right grouping header. Disabling the grouping header did the trick. Thanks  8)
