Author Topic: Error message  (Read 861 times)
NickIst
Presumably while or after copying files into external device
MusicBee v3.4.7764.37422D  (Win10.0), 4 май 2022 15:59:
System.IndexOutOfRangeException: Индекс находился вне границ массива.
   в #=z1v6HwQ___W9fot3mUPBSD6cwyKsC.#=zHwvvkKRU_1Sd(#=zy_Zpyq3VZ9tD #=zVodYV8U=, Rectangle #=zyIeFWSCWUOtL)
   в #=z1v6HwQ___W9fot3mUPBSD6cwyKsC.#=zHwvvkKRU_1Sd(#=z66JHsCuXzfaD #=zp0zifZ0=, Boolean #=zV7qbRycJF38UEFkjaw==)
   в #=z1v6HwQ___W9fot3mUPBSD6cwyKsC.#=zeRbH5biG0OQm()
   в #=z1v6HwQ___W9fot3mUPBSD6cwyKsC.#=zYObjYwOeJfvV(Rectangle #=z82sMU8YvCp00Wq_Vx1Nz7ho=, Rectangle #=zyHGTvFECR3SDQ_lQ505MPzI=)
   в #=zU65coFN0oT5MpzQh4HqhIsE=.OnResize(EventArgs #=zp6b9u0U=)
   в System.Windows.Forms.Control.OnSizeChanged(EventArgs e)
   в System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
   в System.Windows.Forms.Control.UpdateBounds()
   в System.Windows.Forms.Control.WndProc(Message& m)
   в System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   в System.Windows.Forms.Form.WndProc(Message& m)
   в #=zU65coFN0oT5MpzQh4HqhIsE=.WndProc(Message& #=zcfoc3z0=)
   в #=z1v6HwQ___W9fot3mUPBSD6cwyKsC.WndProc(Message& #=zcfoc3z0=)
   в System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   в System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   в System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
The error relates to resizing the panel but not enough info for me to do anything about it.
If it happens repeatedly, can you send me a link to your settings file and instructions on how to reproduce
alannalee
I just got the follow:
MusicBee v3.4.8033.18564D  (Win10.0), 8 Feb 2023 14:32:
System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at #=zR$vgbuAEQVuplvhnGQZwGkU=.#=z36lK_ru9kJHu.#=zn71J965Ip2ZM()
   at #=zR$vgbuAEQVuplvhnGQZwGkU=.#=z36lK_ru9kJHu.#=zHaJa6cs=(Boolean #=zUWc4L450HKJF)
   at #=zWIZyVUuxNLL39$ggm5ULXcz19Z0b.#=z7dQF4bubsPYy.#=zHaJa6cs=(Boolean #=zUWc4L450HKJF)
   at #=zWIZyVUuxNLL39$ggm5ULXcz19Z0b.#=zVIp7KeZqLjlj.#=zJA9gJ9dnUzRg(Boolean #=zVXMcQ25HnPqm)
   at #=zWIZyVUuxNLL39$ggm5ULXcz19Z0b.#=z3NpcPp$nkhJV(#=z7RwQyW8Th6QHsV0jbT0LtTw= #=zOmGwRczxXHhl, Boolean #=z3MEQ39bT5uvM, #=z2MICJYw= #=zhh3z$Yw=, #=zF8vLNjBttrIGhtDChtxMckw= #=zeP2KPnV5WAYb, Boolean #=zkAsAGOckhZFF, #=z55UnGJkz438D$FbrQuQIsgY= #=zryqSNH$ks9hL, #=zcgphzY1FyTworB$LCPvBGXc=[] #=zm8QQOw4XuaG6, Boolean #=z6Qt6UuXFEy6Y)
can you post a screenshot of the main panel
