Author Topic: CD Burning  (Read 26349 times)
WannaBee
Would calling an external CD-burning app through the command line be the best, or - the most expedient solution? I suspect that many users shy away from command-line options. Also, may users may prefer to use their own CD-burner app i.e not be stuck with one that is preselected for them. Users should be able to point to the executable of their favourite burner to be used as the default.
Question: Would it be possible to provide an option to burn a CD direct from, for example, a playlist inside MusicBee? Right-click>Burn?
For those interested, here is a list of more excellent free CD-burners to consider:
CD Burner XP: http://cdburnerxp.se
Ashampoo Free Version: http://www.ashampoo.com/en/usd/pin/0710/Offline/Ashampoo-Burning-Studio-6
Burrrn:http://www.burrrn.net/?page_id=4
