Author Topic: Change color of stars in the expanded album view?  (Read 1504 times)
RawkLee
They seem to be linked to the color of the text. The only thing I was able to find was changing to the desired color, and then setting the track to a custom virtual tag, but that that leaves the rest a different color like this:
So I'm wondering if there is a way to change the track number and time to another color, or just a simpler way that I seem to be missing?
  • Heal The World
There doesn't seem to be a way (for what you want to achieve).
Looks like somebody had a similar issue a while back. But what worked for them doesn't seem to be a solution in your case.
You'll probably have to make a wishlist request (an option to only change the colour of the rating stars) if you're going to get this working the way you want.
