Author Topic: How to retain source files  (Read 484 times)
Chamomile
Hi, I'm a tech noob who is new to this software.
Sorry if my explanation is incomprehensible...
Any help will be greatly appreciated!
Problem;
I can't find the source files of the music I imported from Walkman after I edited them on MusicBee, and it causes all the edited music files to vanish
Background information;
I record music on Walkman using a recording cable, and then import them to MusicBee so that I can edit the titles, artists, and so on.
I import the files from Walkman to MusicBee using drag-and-drop, moving files from the "NWWM_REC" file in Walkman to "All Artists" category in MusicBee.
After editing, I right-click on the edited file on MusicBee and choose "Send to" > "Device Walkman(E:)."
Usually it won't import the files to Walkman somehow, so I always use drag-and-drop afterwards (if you could give me a solution to this phenomenon, that would be beyond helpful).
At first it worked, but after a couple of times I realized that MusicBee began to say something along the lines of "the source file is missing" when I double-clicked on a song and I can't play that song on MusicBee.
After I disconnected Walkman from MusicBee, I also realized that the corresponding files were missing from Walkman.
I used to rely on Music Center for PC, but stopped using them because my files often got missing out of the blue.
Now I changed my music manager to MusicBee, but it seems I can't get a hang of this software on my own.
How can I import files from Walkman, edit them on MusicBee, and then import the edited files back to Walkman without missing files?
vincent kars
Looks like you want to use Musicbee to tag the files on the walkman only.
A simple one is
create a new library "walkman"
point it to Walkman(E:)
Set its monitored folder to Walkman(E:)
Connect the Walkman and select this library in Musicbee.
Now you are simply editing straight on the walkman.
Chamomile
Thank you so much, Vincent!
I followed your guidance and think it's working!
