Author Topic: Radio Stations Questions  (Read 678 times)
Gendji
1. If I export - import Radio Stations (with xml), the station pictures are all lost?. Somehow they do not get exported.
What can I do to prevent that from happening?
2. If I import a different xml file with stations I do not have, does that overwrite my existing stations or do they get appended to the existing list?
1.  "Yes."  This is behavior that would need to be modified by Steven, and because links to images change it may require base64 storage of images in the xml, which though doable may not be practical.
2.  I "think" it would overwrite;  never tried but you can volunteer  ;)
The Wishlist has included requests for the ability to import a .m3u/8 playlist directly into the Radio Station xml format, which definitely receives my "+1."
Last Edit: February 25, 2022, 04:42:45 AM by sveakul
Gendji
1. Right, so export/import is basically just the links and description. Base64 is indeed an idea, I use that for importing recipes for example with YAML.
2. Weeeell no :), not going to test that and loose the pictures again, just finished everything with an A, from Caprice Web Radio, including images  ;)
