Author Topic: Updating to 3.5  (Read 1937 times)
Gendji
I was wondering how to do that.
I tried to install the 3.5 patch over the latest 3.4 patch but that gave me an error:
Unable to load MusicBeeBass.dll: This could be due to running a patch version instead of installing it or it could be etc..
I white-listed everything needed but that didn't work.
Do i need to install a full 3.5 version first? and if so where do i find it?
Thank you.
You can use the patch to update from 3.4 to 3.5 is you're currently using the Installer or Portable versions. You can not patch update the Store version.
To install the patch version you must unzip the files in the downloaded patch and then copy or move them to your current MB installation. Allow the old files to be overwritten and you'll be all set.
You just copy the new 3.5 MusicBee.exe that's in the ZIP over the old 3.4 one that's on your computer.  It's not an installer, it's a replacement file.
Gendji
Oh right, why didn't I think of that :).
I just assumed, based on other patch files, I see no directories in the zip, so it must be an update/installer file.
Thank you both!.
