Author Topic: Windows 11 taskbar icon is tiny  (Read 2314 times)
finch1000
After upgrading to Windows 11, I have noticed that the icon displayed on the taskbar is tiny. I know this is not a functionality problem with MusicBee, I am just wondering if any one has figured out how to fix it.
NOTE: I have already tried changing the icon to a larger one of my own by right-clicking and going to Properties.
I am guessing you have a high dpi display but even so, MB embeds icons up to 128x128px which should be more than enough for the taskbar.
I suggest asking on a windows 11 forum. If you do find out why then let me know so i can do something (assuming its not just a windows bug)
I have an icon I use for testing to see at what size an icon shows up in different views/applications.
You could try this by changing the icon under Preferences > General > Select icon…
and then easily see what size is used for your taskbar.
download: https://bit.ly/iconsizes
Last Edit: February 22, 2022, 04:48:18 PM by hiccup
finch1000
I will try hiccup's suggestion below and check out a Windows 11 forum if I don't find a resolution there.
Thank you, hiccup! I will try this out.
finch1000
That helped, hiccup! My display is 4K, and Windows 11 is using a 256px icon for the taskbar. I will take one of the icons out of the Customization forum and blow it up to 256px.
Thank you and Steven for your help.
Great.
To be honest I suspected that was the case exactly.
MusicBee's icon contains the sizes:
16, 32, 48, 64, 128
But the (minimum) recommendation for Windows icons is:
16, 32, 48, 64, 256
I am not sure why MB has 128. It is hardly ever mentioned to be used.
I am a bit surprised windows wouldnt have automatically upscaled the 128px icon but in any case I have added a 256px icon and removed the 128px one, but it is slightly different to the smaller ones. I dont have a 256px version of the existing ones
Last Edit: February 23, 2022, 07:53:10 AM by Steven
Are you sure adding 256 succeeded?
My icon tool now only shows it has 16, 32, 48, 64
Slightly off-topic, but perhaps useful to others that are interested in creating icons for Windows applications and stumble upon this thread.
This is a small table I once created as a cheat sheet to see what icon sizes would be sensible to use:
thanks for reporting that. I have tried a different approach of upscaling the 128px image
finch1000
The patch works perfectly. Thank you!
