Author Topic: 50MB File Size Limit with OneDrive library  (Read 851 times)
isaacarnold
I recently uploaded my music to OneDrive, and followed the instructions here (https://getmusicbee.com/forum/index.php?topic=33953.0) to mount the drive. It worked well, and MB is able to locate the library and import all my music - except it appears to be excluding all files larger than 50MB.
This is the error in the error log - https://imgur.com/4QTiA4L -  there are some albums where songs under 50MB have been added and those over 50MB haven't, so I'm reasonably confident that 50MB is the size cut-off, I'm just unsure as to why.
If I copy the same files elsewhere (e.g. the local Music folder) they scan into MB without issue, despite their size. When my library was stored locally I never encountered this issue despite having many large files.
Does anyone have any ideas on how to remove this limit?
For reference I'm using the Microsoft Store version of MB on Windows 10.
isaacarnold
Update - I've followed the instructions here (https://thegeekpage.com/fix-the-file-size-exceeds-the-limit-allowed-and-cannot-be-saved/) to increase the file transfer limit for Windows, and it appears to have worked.
Hopefully this helps anyone else in the same boat trying to migrate their library from local storage to the cloud :)
