Author Topic: Unwanted auto added tune  (Read 1253 times)
Mikelap
My problem is about a setting i have somewhere in Musicbee that i want to remove and i dont know where it is . The issue :  i choose a tune to play  while it plays i browse an other album as soon as i open the album the first tune on the album i opened to browse will play next after the current tune  i did not  add in any way this tune it adds itself .Any of you know where that setting is so i can turn it off ? i have Musicbee on another PC snd it doesnt do that .Thanks
PC Windows 10>Musicbee>Quad 405>Burson Conductor >Pioneer SX750>Woo Audio22>FLUXION AV-7 S.E.T. Speaker amp>FU32+6N2 AMP.>Asus Essence STX>CmoyBB>Sennheiser HD800S >Grado RS2E>DENON LA-D5000 LITE >DENON AHD-1001,Kef 104,Klipsch KG 5.5
Check the settings under Preferences > Now Playing > playing tracks list
Mikelap
My setting are the same as on my other PC and it still does the same thing i tried different settings same thing Also i notice even if i choose an entire album to play if i just open another album when the tune is finish it will play the first tune of that other  album
Turn off Edit-Edit Preferences-Now Playing...playback...playback follows cursor
Mikelap
Well that did it works like before .Thanks alot. what's weird is that it never happened before and i never changed that setting i had that setting on,on both my PC i would venture to say that maybe its update related  .Both PC's are on same version ( the latest one )
Updates do not change settings.
But at least you got it working.
