Author Topic: Library filters in AutoDJ and Auto-Playlists  (Read 3757 times)
this has been asked for a few times, so anyone interested to try it out, you can now choose a library filter as the criteria for the Auto DJ and auto-playlists. This library listbox has been expanded to include the filters in the drop-down
http://www.mediafire.com/?cfvu6cfd4cm6eoz
OrB
Thank you for implementing the library-filters
minor problems:
1) auto DJ -| apply filter: custom filter |- is not used if a library filter is active
2) auto-playlist and library filter work good together
- but the active option is set to folder instead of library when reopen auto-playlist-edit-window
can you explain some more. I am not finding any cases where the auto-playlist is not remembering the selected filter or not setting 'library' as the source
i've updated the weekly update link with the fix for 1
Last Edit: June 05, 2011, 10:45:35 PM by Steven
OrB
there is no problem till reopen the window  - it works like expected but looks like this
http://www.mediafire.com/?rqitc2esrdz6emu
weekly update link updated with fix for 2 (although it doesnt happen for me i can see what its likely to be)
OrB
Auto-DJ - OK
Edit autoplaylist : now nothing is selected
library - playlist - folders : inactive
Last Edit: June 05, 2011, 11:06:25 PM by OrB
