Author Topic: Remove "(Abum Version)" "(Explicit Version)" etc. from song title for multiples?  (Read 984 times)
rgujiohgrwuio
I have albums where, after each track title, it'll have something in brackets that I want removed. It becomes tedious having to do it for multiple songs.
Examples can include but not limited to: "(Album Version)" / "(Explicit Version)" / "(*Year* Remastered Version)" etc.
Is there any simple way to remove these? Some songs may contain opening/closing brackets as part of the official title but
NB: I'm not talking about renaming the file as its displayed in Windows Explorer (PowerRename in Windows PowerToys works really well for that), I'm talking specifically about the "Musical Properties' Title" field.
[Edited] The built-in Search and Replace tool allows regex searching (so you should be able to search for something that starts and ends with parentheses), but if that doesn't work try the Additional Tagging & Reporting Tools plugin.
rgujiohgrwuio
This worked! Many thanks :) <3
Steps for anyone who finds this later:
0. I would always recommend making a backup of your library in case you make a mistake.
1. Select all applicable songs (I selected the entire library to remove all instances)
2. Tools -> Tagging Tools -> Search and replace
3a. In "Search For" type what you want removed (e.g. Album Version).
3b. In "Field" I put "Any Field"
3c. In "Replace With" leave empty
4. Click "Preview" then check over all files, if you're satisfied Save.
Good advice. The only thing I would add, between 0 and 1, is to test on a couple of tracks/albums before you apply to your entire collection.
