Author Topic: Anybody care to share their settings?  (Read 4930 times)
How that's accomplished in the MB code is beyond me - I really suck at scripting :-[
I thought I did also, but give this a try for album - artist:
https://rateyourmusic.com/search?searchterm=<artist>%20<album>&searchtype=
And this for artist:
https://rateyourmusic.com/search?searchterm=<artist>&searchtype=
EDIT: swapped the placement of <artist> and <album>
Last Edit: February 10, 2022, 10:29:53 PM by phred
Mr. Trev
Sorry to disappoint, but that fails even more spectacularly
It'll search out the first word of the album or artist, then give a bunch of errors in new tabs for each of the remaining words
So help me understand what's going on here: "$Replace(<Artist>," ",-)"/"$Replace(<Album>," ",-)"
My current understanding is that should replace any " " in the artist/album name with a "-". I've tried changing the variables ( - to _) but that didn't have any effect on the link it was creating.
I also get why created link is capitalized (that's how my tags are), but why does it matter. Shouldn't weblinks be case-insensitive?
I don't know if you're replying to me or to psychoadept. What I posted is working. Have you tried mine?
I don't have any "$Replace" functions in mine.
Playing around a bit, this seems to work for Mr. Trev's example:
https://rateyourmusic.com/release/album/$Lower($Replace(<Album Artist>"/"<Album>," ","_"))
But I haven't succeeded in getting Phred's example of: "Grateful Dead - Europe '72" to work.
The apostrophe seems to be the problem there.
Getting rid of it using a virtual tag is working fine within MusicBee, but using the same formula in an internet link fails, and the apostrophe will roar it's ugly head again.
I have no clue why that is.
edit,
While this seems to work for Mr. Trev's example of "Lightning Dust", it fails for most other releases.
It looks like RYM is inconsistent in using an underscore, or a minus sign as a replacement for spaces in album/artist names:
https://rateyourmusic.com/release/album/lightning_dust/infinite_light/
https://rateyourmusic.com/release/album/ane-brun/leave-me-breathless/
Not sure if/how that can be solved?
Last Edit: February 10, 2022, 11:13:30 PM by hiccup
I swapped the placement of "artist" and "album" in the code above and it works with the apostrophe.
So for now for RYM I myself will stick to using google as the middle man.
The requested release will almost always be at the top of the search results, only one click away :
http://www.google.com/search?q=site:rateyourmusic.com <Album Artist> <Album>
(I'm sorry for being part of making this drift off-topic a bit)
That leads to a search result page on RYM containing matching releases.
Which is a good result, but I think Mr. Trev (and I) were trying to have a direct link to a specific release.
I don't disagree, but it's now better than what was posted earlier today, which was giving 404s.
I'll be trying your Google > RYM link shortly.
Mr. Trev
Sorry about that. The first part was referring to your post Phred
No joy what so ever. It did just occur to me however, that I am using Brave and maybe that or one/any of the extensions I'm running could be messing with it.
The rest of it was referring to psychoadept's post. I was wondering if I was correct in how it is supposed to work
I'll play with it some more tonight…
This works well and I have replaced mine with yours. Although I have changed <Album Artist> to <Artist>.
Thanks.
Last Edit: February 11, 2022, 12:33:19 AM by phred
Mr. Trev
OK, this whole thing is smarter than me
Using Hiccup's google middle man, I get one tab with a Google result just for RYM's website. The other 4 tabs are: http://lightning/, http://dust/, http://infinite/, http://light/. (BTW, I tried with Brave, Librefox, and a portable install of Opera)
I appreciate all the help you guys are putting in, but at this point, I'm just going to wait for a proper API to be released for full integration
I hope, at least, you guys can get some use from it
Why?
Because I have a boatload of albums by Various Artists and  I'm researching the specific artists.
And it works equally well when there is a "real" album artist.
Any reason to search via Google instead of going directly to Rate Your Music's own search page?
https://rateyourmusic.com/search?searchterm=<Album Artist> <Album>
Nope, just a habit that I probably copied from another link a while ago and never gave much thought.
Using rateyourmusic.com/search is indeed much better.
